Audio amplifier has short circuit
Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier
pls help
Make, model and a few pictures of the boards inside would help. You give us little to go on here. In general, with a direct short like this, look at the bridge rectifier being shorted (if there is one) or if this has a switching power supply, check the main transistor (should be on a heatsink).
Update this with the above info and we should be able to provide more detailed suggestions.
这个答案有帮助吗?
I am unable to upload images but its peavey cs 2000 power amplifier
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 1,957
Is your amp repaired??
由 Mallon Mbewe 完成的
Hi im roldan from cebu .my question is..what can i do the speaker out is bad tune ( mahina parang short ,)not fully higher tune.im using 1 channel only cause the other channel is broken .
Thank you.
由 Kuya Reinz Bustillo 完成的
Hi @Kuya Reinz Bustillo,
What is the make and model number of the amp?
由 jayeff 完成的
Ask ko lang po kung na short circuit yung amplifier means madadamay po ba yung speaker ? Salamat po
由 Michael Geronimo 完成的
