跳转到主内容
修复你的物品
维修的权力
配件 & 工具
享受iFixit的提示和技巧。
27 个问题 查看全部
Proper way to drill through metal?
I need to drill very many small holes (1/4 inch wide) through the metal of a shipping container the kind that are loaded on ships and on the back of trucks. The wall thickness is aprox. 3/16th of an inch thick. Problem: I am going through drill bits at a very high rate. I am getting only 12 holes drilled before the drill bit is worn out and I have to keep replacing with new bits. Am I doing something wrong ? Please tell me if there is some way to extend the life of the bit. Using WD-40 ? Some other oil ?
thank you
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Also, I forgot to ask if using a drill bit for metal is harmed if I also use it for drilling through wood ? In this case pine.
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
Hi @ramses2 ,
Try drilling at a slower speed, approx 1500 - 2000 rpm, (or even slower if you like) to reduce the heat build up which causes the drill bit’s cutting edge to go blunt,
If you’re using HSS twist drill bits (high speed steel) try using Black Oxide or Cobalt Steel twist drill bits as these will last longer.
You could use a multipurpose oil -example only to reduce the friction and therefore the heat build up but it may be a bit hard to apply if you’re drilling into the side of the container and not down onto it so the oil stays there.
Pine is a soft wood so you won’t harm the drill bit.
这个答案有帮助吗?
得分 3
评论:
thank you. that answers my question
完成的
添加一条评论
添加你的答案
Richard Whiting 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 58
总计 253
