跳转到主内容
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
40 个问题 查看全部
Slow and fluctuating transfer speeds in Finder on High Sierra iMac Pro
Hi, I was wondering if anyone has experienced anything similar.
I bought my iMac pro back in June, and I’ve been experiencing weirdness regarding finder transfer speeds.
I work in data management in the film industry, and while copy / paste-ing let’s say about 700 gb between my fast RAID setup and an external hard drive, the finder will tell me that it will take about an hour to copy these 700gb worth of files.
But then 40 minutes later it’ll say 8 hours or so. Unless I start working on the mac again (move the mouse etc) then the speed picks up again.
And it’s also been slowing down transfers to drives that I just bought.
Is this a High Sierra issue, or is this an iMac Pro issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would suspect a lack of available “scratch disk” space.
Click the Edit application (Mac) menu, point to Preferences, and then click Performance. Select the check box next to the scratch disk you want to use or clear the check box to remove it. Some applications hold scratch disk space as long as the application is open. To delete scratch disk space you must close the application.
Also how much RAM are you using and is this when using a particular application?
这个答案有帮助吗?
得分 2
1条评论:
As this was just a copy / paste function in the Finder (no application used), I don't think a scratch disk setting would change things (is there such a thing in the Finder? ).
The thing is, if I use terminal to copy the files, this slowdown doesn't happen. It only happens when I either drag&drop or copy/paste in the finder.
I'm beginning to suspect High Sierra.
完成的
添加一条评论
添加你的答案
benni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 552
