Samsung Galaxy S5 display replacement
Hi,
I have removed the broken display from my phone, unfortunately the copper labels are damaged. Could this be a problem with a new display. Should I replace them and if yes where can i buy them?
Hi Smint,
The copper labels should not make a huge difference if you do not replace them. That being said if you do want to just in case you would probably want to buy a whole mid frame assembly with them attached. Galaxy S5 (Verizon) Midframe
Good luck!
这个答案有帮助吗?
Thank you very much for your answer!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 35
