跳转到主内容
这是一台发布于2012年的笔记本电脑,在日常使用环境中非常耐用。电脑配有13寸的屏幕,500G的硬盘,4GB的内存,Windows8.1系统可以在上面流畅的运行。
24 个问题 查看全部
Help, can't install an OS
So here’s what happened, I tried to install Ubuntu onto my laptop and when I restarted it, well it didn’t detect any OS anymore despite me leaving the USB inside. (It was originally a windows 10)
Now whatever I do, it doesn’t detect any USB input, let it be a USB keyboard, mouse or drive. The only thing I have access to is my BIOS.
It doesn’t seem like my laptop still has an OS and it refuses to do anything else.
Letting it boot normally gives me:
“All boot options are tried. Press F4 key to recover with factory image using Recovery…“
After pressing F4, well it doesn’t detect anything and goes on it’s merry way back to the afore mentioned quote.
Thanks is advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @kansysaea ,
In BIOS change the Fast BIOS mode setting to disabled
When Fast Bios mode is enabled it skips USB check during POST.
Go to BIOS > Advanced > Fast BIOS mode
When exiting BIOS (F10) save the changes (Y).
When the laptop restarts you should be able to boot from a USB device.
这个答案有帮助吗?
得分 3
2条评论:
thank you very much @jayeff for your wonderful advice. It works
完成的
Thanks jayeff ! , works too in UEFI mode
完成的
添加一条评论
添加你的答案
Andrew Kansy 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 9
总计 1,694
