跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Issues with Samsung SSD's!
Hi, i have same issue, Beware iMac 27 mid 2011, don't work with samsung 860 EVO (Because samsung use unsupported new controller) Also same situation can be with 850 EVO (I didn't check with this series), so optimal for upgrade without any risk will be use 840 EVO series. Symptomatic is next: When you connect 860 EVO (I check it) or 850 EVO (I didn't check it 850 EVO, so info for 850 EVO maybe not correct).
You can start from internet recovery but you cannot do fusion drive, for fusion drive you should start from USB recovery, yes you can do fusion drive with 860 EVO or 850 EVO but then when will be recovery from time machine you will se error and time machine is stop, then if you will try install new system to you new fusion formatted disk, you will cannot install, not sierra, not sierra high, maybe el captain will work but you will see many error when install it (6 hours maybe), if you still install some OS don't start to be happy, because will be many errors and white screen.
So by the way. If you try to instal os to pure ssd, it's also will be with error. So conclusion don't use 860 EVO and 850 EVO with iMac 27 mid 2011 (I have core i5 3,1). So your SSD will work with USB 2.0 on your iMac, or need to buy thunderbolt ssd adapter or thunderbolt usb 3.0
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The 2.5" SSD works just fine! Somebody FUD'd you!
I've put in over 30 Samsung drives into both 21.5 & 27" iMac's
Sounds like your expecting something to work which won't. First you need to install it correctly following the IFIXIT guide here: 安装iMac Intel 27" EMC 2429 双驱动器组件(机械硬盘或固态硬盘) You also need to have already setup a bootable OS installer with the OS you want to run. I would recommend sticking with MacOS Sierra. Thats assuming you are trying to setup a dual drive setup. Which is what I would recommend!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
inizovtsev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 649
