跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
Replaced microphone but still won't work
The microphone of my DS Lite isn't getting anything any more. I bought a new one, followed Ifixit guide to replace it (great guide!). Now I have everything back in place, but it still doesn't work... What could I do next? I guess, I can only go buy a DSi ... Other ideas to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Same problem, tested it with new mic but still not working.
完成的
添加一条评论
2个答案
已选择的解决方案
i'd check that the microphone connection is on the motherboard correctly... it can be tricky little connection.
这个答案有帮助吗?
得分 2
添加一条评论
Although it seems unrelated, a faulty headphone connector can also cause this if the internal connections are shorting.
Easiest solution is to replace the connector.
The same problem can occur on the DSi, but I've not seen it on any later models.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pascaldossin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 981
