跳转到主内容
Guides and support for various television (TV) brands and styles.
9048 个问题 查看全部
My TV shows no sign of having power?
My LC-50LBU591U shut off suddenly as I was watching TV earlier today. The blue light that would appear when the TV is off is now gone. I cannot turn it on with the power button or remote either. I tried holding the power button for 30 seconds with it being unplugged and no luck.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello John N, my name is John. with the symptoms you have describe it sound as if the power board died on you. i would look up a new one and replace it being the t.v. is a 50” and all it would be worth it and a relativity easy fix. Any questions feel free to ask.
这个答案有帮助吗?
得分 0
2条评论:
Is there a specific one I would need to buy? Are there compatibility issues I need to know about? And how easy or hard would this task be?
完成的
best steps to follow,
1: lay t.v. screen down on a soft surface like your bed.
2: remove the screws from the back edge and input connectors as well as the stand.
note: back should lift off every easy if you have a struggle there is another screw to be removed.
3: take pictures of the power board it would be the board that the plug goes into.
note: leave wires in power board until replacement board comes.
4: google search your make and model T.V. of a replacement power board. reference images with the ones you took.
5: it will be 4 to 5 screws to remove power board and squeeze connectors for the wires.
6: after replacing board lift t.v., plug in, test, and put back together.
完成的
添加一条评论
添加你的答案
John Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 57
