跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch ID + Flex Plate connector ripped
I was replacing a broken screen on my iPhone 6 Plus and I ripped the connector out from the flex cable that is built into the metal plate that come accross the screen. My question is if I replace the metal plate with built in flex cable, will my Touch ID work? The home button seems fine.
Thanks a lot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
As long as you didn’t damage the HB, then it will be fine with a replacement heat shield/Link flex.
这个答案有帮助吗?
得分 2
添加一条评论
Yes, as long as your home button isn't damaged - you can just replace the back plate with a new home button flex
这个答案有帮助吗?
得分 1
2条评论:
@retechmobile If you agree with Minho or think his answer is helpful you can just hit the helpful button instead of reposting what he said...
完成的
Ok, my bad. Thank you for pointing out that option
完成的
添加一条评论
添加你的答案
Fernando 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 79
