跳转到主内容
主板和 CPU 维修指南。
165 个问题 查看全部
ASUS H110M-D Can't find IDE mode in BIOS.
Hi Guys!, I just want to ask if Asus H110M-D Mother Board supported the IDE mode in the Bios.
thanks for the help guys!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you need to configure or set up your computer motherboard’s CMOS, BIOS, or chipset, see the Motherboard CMOS Configuration and Setup page for instructions.
I believe the setting you want is to set “SATA Mode” to “AHCI.”
这个答案有帮助吗?
得分 1
2条评论:
Yes how to do it? because there is no setting in BIOS of IDE and AHCI only SATA.
完成的
It took some digging, but this is what I found:
Because the Intel H110 chipset only supports AHCI mode, there might not be an additional option about SATA mode under BIOS.
完成的
添加一条评论
添加你的答案
Joebert Lazano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 3,592
