跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
421 个问题 查看全部
Dropped My MacBook and the screen is all over lines
I dropped My MacBook air and when I picked it up it looked finn but then when I opend it it had colored line over the screen. Everything works fine but this lines are in My way and I don’t have time to go get it fixed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@agustama
since this showed up after a drp you most likely have a bad display. To verify this add some pictures of what your screen shows with your question. That way we can see what you see. 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
最有帮助的答案
Plug in your system into an external monitor, If the image looks good your display assembly is damaged and will need to be replaced.
MacBook Air 13" Early 2015 Display Assembly Replacement and here’s the needed part MacBook Air 13" (Mid 2013-2017) Display Assembly
MacBook Air 13" (Mid 2013-2017) Display Assembly图片
产品
$314.99
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Agusta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,647
