跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Won't power on. Fan on for a 2 seconds and turns off, repeats
My MacBook Pro mid 2014 13” was all working and all of a sudden yesterday it turned off.
Things I did to check before opening my Mac:
  • Shutdown my Mac by pressing power button for 10 seconds, and turned ON - tried resetting PRAM.
  • Similarly tried resetting SMC.
Result: Nothing happened no chime or display.
So opened it and disconnected the battery tried with just main plug still same results.
But! I noticed that, when power button is pressed, fan spins for 2-3 seconds and stops and repeats. Then the CPU, SSD gets hot. I then removed the battery and power supply.
Last try, I disconnected SSD, side WIFI board and turned on, still same result.
If it is a logic board issue, anyone know which part failed it would be helpful.
If anyone recognize this problem, please help.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The power control logic near the CPU and/or the CPU its self has failed. Here’s the IFIXIT guide you’ll need to follow to replace the logic board MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement, you’ll find the logic board options within it.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much.
Is this the only reason or is there a chance of any other issue ?
完成的
添加一条评论
添加你的答案
vaidhya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 195
