跳转到主内容
第三代 Surface Pro 平板,发布于2014.6.20
123 个问题 查看全部
I replaced the cracked LCD but the backlight doesn't turn on.
Will replacing the motherboard fix the Surface Pro 3 LCD backlight problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
There is a plastic bridge connector part that connects the ribbon cable for the screen to the logic board and has a screw to hold it in.
If that is missing the screen won't connect properly to the board. It's easy to lose that part when you unplug the screen.
完成的
I'm well aware of that. The bridge is in place and I can see the display by shining a light on it. It is only the backlight that isn't working. Thanks anyway.
完成的
I was going to try replacing the MB but found an entire unit missing only LCD and SSD for about the same cost. Means I will have a lot of small parts available for sale. Lew at lew@lewmur.com Includes a new battery.
完成的
添加一条评论
1个答案
最有帮助的答案
It’s possible that your replacement screen is a dud too. Connect your Surface to an external monitor and see if anything shows up.
Update (11/24/2018)
Sounds like you scored a deal! Now you have spare parts for your surface if something else breaks. Hopefully a motherboard swap solves your problem.
这个答案有帮助吗?
得分 1
1条评论:
Been there, done that, got the T-Shirt. Screen works in another Pro 3.
完成的
添加一条评论
添加你的答案
Lew Murray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 260
