跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Phone drains all batteries put onto it even after calibration
As the title says.
Have replaced the phone’s battery thrice. Have calibrated all of them and have fully reset the phone via its option in the settings.
Still, this son of a ##&&%’s draining original batteries at 90% their original charge like they’re at 20%. There isn’t even any abnormal heat off of it. I don’t know what else to do.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Rapid discharge can be caused by a faulty Tristar IC. Otherwise, you may have a modular component that is drawing excess current. The phone won’t normally get abnormally warm/hot even if it is.
If you turn brightness on at full, set the Auto-Lock to never, close all the apps but leave the radios on, the phone should last around 4-5 hours. If you’re not getting that, then consider using only the screen and battery and test it that way. That eliminates most of the modular components. Then try it with a known good screen if it stills drains quickly. In the end, you will be left with only the logic board as the culprit.
这个答案有帮助吗?
得分 3
3条评论:
My friend, thank you very much for taking the time to answer both my problems. As a battery test, I usually turn bluetooth, wi-fi, brightness to max, and set the phone recording video with the flashlight on to discharge it as quickly as possible. While proper batteries last about an hour and forty or so, this phone makes it last half hour. Will attempt the test you have suggested and I'll get back here then.
完成的
Edit: Well, actually, doing the test I mentioned lasts the battery 1:29, which is actually not bad and may already tell something on its own. The value I mentioned before was based on a short test I made reliant on the percentage it lost per minute as opposed to letting it go 100 to 0. It'll take its time, but I'll run the above mentioned tests.
完成的
The actual test matters less than running it consistently :>). When I have a chance, I run batteries against a dummy load with data capture & graphing capabilities. That tells me everything I need to know.
完成的
添加一条评论
添加你的答案
Smeargle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 55
