跳转到主内容
The dv5-1125nr is an multimedia entertainment laptop that features a 15.4" display, a built in camera, and toggle touchpad
11 个问题 查看全部
Won't turn on with battery in after it been sitting a while
First off the model is dv6-7210us, but that was not one of my choices on here.
I have a weird scenario. I bought a new battery for this laptop. When you first plug in the battery and press power it works fine. The battery reads and charges. However, if you leave it sit shut off for like an hour or more then press power nothing happens. It doesn't matter if the power cord is plugged in or not. I have to pull the battery out and either plug it back in or just run it off the power cord to turn it on. Can't seem to figure this out. This is something I am donating to a learning facility for kids with reading problems. I need this to work right.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Hi @scooby316 ,
Try running the battery test and calibration in the HP PC Hardware Diagnostics program and see what it shows. (look under Running Component tests > Power test > Battery test)
Here’s a link if it is already not installed on the laptop.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Thomas Albamonte 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 169
