跳转到主内容
Why after putting back together am I getting folder with question mark
My daughter about 4 months ago had a friend spill coke on her laptop. Keyboard stopped working. Took apart the laptop to clean up keyboard. Put laptop back together and it went to the sign in screen. I left it on that screen so she could login. In the morning when she tried she said it would not power up. I tried it and yes it powered up but gave me a notice, "you need to reboot" I did and now all we get is a white screen with a folder blinking and a question mark in the middle. When I start it up I get the Apple "chime" then the flashing folder with a question mark.
Have tried all the standard procedures, ie. reset PRam, start with the X key, start with the option key, start with the C key, etc.
I have not tried the boot disc as I am afraid I will loose everything on the drive. Does anyone have any other suggestion on this problem. I appreciate all the help I can get.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
This folder means your machine cannot find a Startup Folder. You system may be corrupt, hard drive may have failed or your connection to your hard drive may not be secure. Try starting up from your system installation disk by inserting the disk and restarting holding down the "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select your hard drive on the left and run the repair till there are no errors. Let us know if this solves the problem.
这个答案有帮助吗?
得分 4
2条评论:
What if i have no disk
完成的
That too would fit here, as the system can't find the needed OS files to boot up. A bad SATA cable can also cause this.
Do you have a bootable external drive (OS-X) to test things? With it plugged in (and powered) hold the option key so you can select the external drive.
完成的
添加一条评论
添加你的答案
Kathlene Crawford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 603
