My power supply buzzes when im playing games.
I’ve tried multiple PSs and they all make buzzing noise while I’m playing
it stops immediately after exiting the game
note:all of the pc parts are new except for one hdd.
could it be a virus? I’m suspecting a cracked game to be the reason , couse when i changed the MB the sound disappeared until I lunched the potential reason.
8条评论
Hi @falcon_f5 ,
Just an observation, but are the PSU adequate for the task?
When playing games more power is required as the hardware needs to perform to cope with the demands of the game.
For example if you have a high end graphics card installed what is the recommended PSU power (wattage) required as shown by the card manufacturer for the graphics card to perform as designed.
Is the currently installed PSU operating at its' upper limits to accommodate the card?
由 jayeff 完成的
PS wattage is more than enough run the pc.
650w
GTX1070
Used to make the same noise with my GTX960
@jayeff
由 Khaled 完成的
Hi @falcon_f5 ,
Fair enough,
The specs say 500W so it is as you say, more than enough.
由 jayeff 完成的
Hi @falcon_f5 ,
You say you suspect a virus.
Have you done a full virus scan of the PC then, to prove or disprove that it may be the cause?
由 jayeff 完成的
I have not, but I’m planning to do a full format to the system after this semester (4 weeks drom now) but i will try scanning it.@jayeff
由 Khaled 完成的
显示更多的3条评论
