跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Top side corner of MBP screen lifting up, needs glue maybe? (Photo)
Hello all. My old 2009 MBP has the back corner screen top lifting up when I close the machine. The screen works fine, and I can push the screen back down in the corner. I assume the glue needs to be re-applied?
I took the machine to a local repair shop, and they wanted to replace the entire top half of the machine, including the LCD screen, which I really can’t afford, and I’m not sure it needs to be replaced. Otherwise the machine is still going strong after almost 10 years.
If anyone has dealt with a similar issue, please let me know.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Take a look at this video and see if it helps, you may just need to tighten hinges and that may be enough but it looks like the metal blocks for hinge reinforcement have separated from the top chassis and may need to be reglued with epoxy.
https://www.youtube.com/watch?v=Gi6vlshg...
这个答案有帮助吗?
得分 5
4条评论:
That is super helpful, thank you Ben. I'll update when I can get home and try this.
完成的
I'm with @benjamen50 here! Epoxy is the ticket! But you'll need to get the display apart to clean the old glue and you'll want to scuff up the surface to make a better surface for the epoxy to adhere to.
Here's the IFIXIT guide to take your display fully off: MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Display Assembly Replacement and here's the IFIXIT guide to take the display assembly apart MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement Jump down to Step14 and pick it up there.
Once the display is out you can clean and sand the pulled areas. You'll want to place a display frame & cover on a good flat surface with a wood board going on top with a bit of weight for a good 24hrs for the epoxy to cure. I would also place added epoxy around the frame at the glue points to add more strength. Just make sure you don't go into the areas the display fits into. And don't forget to sand the surfaces to give the epoxy a better grip!
完成的
Thank you so much for the extra info and links Dan. I think you're correct also. After looking inside, I don't think it's the hinge, but the display coming apart.
完成的
I have this issue too can anyone recommend me a good brand for epoxy ?
完成的
添加一条评论
Chances are its from apples terrible design of having ALL the hot air from the cpu and gpu blowing on the hinge glue. Not your fault. Put some new epoxy and it should be fine
这个答案有帮助吗?
得分 1
2条评论:
Thank you Ethan, I think you're right that the hot hair has had an impact over the years.
完成的
For sure. Good luck
完成的
添加一条评论
添加你的答案
nicholas.he 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 547
