跳转到主内容
加入维修社区 - 创建账户
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Why won't my lcd work?
I just attempted to replace the lcd and digitizer on an Ipad Mini 2 LTE. I connected everything correctly, but the lcd won’t turn on. The Ipad is recongized in Itunes. I would try to back it up but I can’t allow the computer to be accepted. I tried 3 three lcds. The previous broken one lit up, but was gray and orange with line. Is there some fuse burned out on the Ipad.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Let’s rule out a backlight issue. Shine a bright flashlight onto your iPad’s screen at multiple angles and see if you can make out any pictures on the screen.
这个答案有帮助吗?
得分 0
2条评论:
I have tried this a few times and none of them have worked.
完成的
That sucks! I am not the iPad expert around here so don't give up hope yet. @refectio knows iPads better then I do, maybe he will drop by and suggest something!
完成的
添加一条评论
添加你的答案
Isaac Stromberg 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 138
