跳转到主内容
Successor to the popular Samsung WB150F, the WB250F emphasizes sharing capabilities with Samsung's Direct Link and Smart Camera App.
14 个问题 查看全部
Card locked can not take photo
When I boot up my camera the screen displays “card locked” and the camera will not take pictures. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Thanks much. This solved my problem. I would have never thought of this solution.
完成的
how to solbe my problem
完成的
添加一条评论
2个答案
已选择的解决方案
You likely need to flip the “lock” switch. If flipping the lock switch to the unlocked position doesn’t work then you are going to be out of luck.
https://kb.sandisk.com/app/answers/detai...
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
This usually means the memory card has failed to the extent it can no longer read, but permanently locks into read-only mode. This is HOW you want your card to fail; performance will probably take a hit but you can still pull your files off. It's a protection measure built into flash memory.
Pull your files off of the card and try formatting it in your camera. If it works, use the card until you can replace it but don’t keep using it. If you do, there’s a descent chance the card will die for good and it may not die gracefully to the extent your data is safe. Cards are cheap; data recovery isn’t.
这个答案有帮助吗?
得分 3
1条评论:
how to solb my problum
完成的
添加一条评论
添加你的答案
Richard Asbach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,366
