跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
How to remove and reinstall Speaker
I recently purchased a replacement speaker for my late 2016 15-inch MacBook Pro with Touch Bar and I wanted to know how to remove the speaker. It’s glued in really well. Do I use brute force to pull it out? Or is there an adhesive solvent I can use. I also wanted to know if you sell the black glue adhesive that apple uses in these MacBook pros?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I would use a heat gun and just 85% isopropyl alcohol. The issue is if you use anything stronger you could get it on the keycaps melting them (Ouch!) And, Yes! Its well glued in. Review the IFIXIT 配备Touch Bar的15英寸MacBook Pro拆解 Step12 to get an idea where the glue is.
Did you try getting it fixed by Apple as Apple did have an extended warranty program which still might be viable.
这个答案有帮助吗?
得分 2
添加一条评论
Success:
I had chattering sound on Prevoius near perfect Mac speakers. I order this right speaker and the tool kit (star wrenches). Removed the panel it took some force because there’s some middle fasteners that pop out And then the panel slides as noted in this and various tutorials from the rear latches.
The speaker is glued in with a gasket like perimeter strip around the speaker. I should’ve taken a video on this since I couldn’t find one but I heat gunned the front of the computer just a little bit so it’s fairly warm to the touch and then used a knife to poke the in place broken speaker and pry it out at one end. Took a bit of force but it actually didn’t damage the removed speaker with only a slight indentation in it’s housing. I used the adhesive gasket like strip to adhere the new speaker therein.
Now I just want to know root cause what blowout blew out the speakers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raymond Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 595
