跳转到主内容
Popular clothes dryer series by Kenmore.
60 个问题 查看全部
My dryer won’t start
My Kenmore elite dryer was working great but now won’t start. I had an appliance repair person come out and tell me that is was the timer. I ordered the new timer and put it in. Still not starting, so I replaced the fuse and the door switch. I’m out of ideas. There is a hum when you press the start button so the power is getting to the timer.
thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Hi @loraola ,
What is the model number of the dryer?
完成的
添加一条评论
4个答案
已选择的解决方案
Most dryers have a thermistor that senses moisture. If your vent hose is linked or the venting through the wall is clogged the thermistor will stop the dryer. The thermistor acts like a fuse. Unplug dryer, remove the back panel. The thermistor is white and rectangle shaped about 1.5” long. Test with multimeter set for ohms. Remove the wires and you should have 1.0 ohms. If you have no ohms it’s bad. One 1/4” screw holds it in place. Easy peasy. Don’t forget to clean you vent hose and the duct to vent outside.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
If it's the motor buzzing/humming when the start button is pushed then it likely has a bad motor. Open the door and manually reach in and rotate the drum in the counter clockwise direction for a couple of complete revolutions and then shut the door and see if the dryer will start. If the dryer starts; this would indicate a bad motor and it will need to be replaced. If it does not start and continues to hum try this; Open the door and press and hold the door switch in. Rotate the drum counter clockwise and have some one press start while the drum is turning. If the dryer starts, replace the motor.
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
这个答案有帮助吗?
得分 5
6条评论:
There is absolutely no question you have a bad motor.
完成的
My dryer also does not start. I don't hear a "buzzing/humming" noise however. It worked fine last week when I used it! Help!!!
完成的
@deehanson Although I agree the problem is probably related to the motor, it's not necessarily the motor itself; it could well be the motor start capacitor has failed and isn't generating enough power to overcome the resting inertia of the drum.
However, it's impossible to say for sure without knowing the make and model of your dryer. Add that information here, Dee, and we'll see if we can help you figure out what's going on with your dryer.
完成的
Hi I have the same issue. Buzzing/humming" noise when trying to start. Switch seems to be fine, click sound there, light goes off when switch is activated. Cant get drum started up with manually rotating it.
Kenmore 110. C76822695, type: CWSR-NAT-1206006-CV22
Please let me know if any ideas. Thank you
完成的
@julio73694
Did you hold the door switch operated when manually rotating the drum to see if it then continued on its own?
完成的
显示更多的1条评论
添加一条评论
Hello Lora,
From what you’ve said it, it definitely is the motor. Here is a link to repair clinic and their selection of motors, and prices; https://www.repairclinic.com/Shop-For-Pa... .
I hope this helps you!
Rich Lilja
这个答案有帮助吗?
得分 1
添加一条评论
Hi @julio73694
If it is hard to manually rotate it could be a faulty idler pulley.
Here's a video that shows how to replace it that may help you to see if it is OK or not.
If the pulley is OK, try removing the belt from the drum and check if the drum rotates easily by hand, just to check that the drum bearings are OK and if so it seems as though there's a problem with the motor.
If you find the problem and it is a faulty part that needs replacing, here's the part list for the model that is useful.
Locate the wanted part in the list and you'll find the manufacturer's part number for the part listed with the part. Search online for the part number to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lora f 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 125
过去 30 天: 489
总计 12,277
