跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
247 个问题 查看全部
Why my radio doesn't start automatically?
Hi!
I just install a new radio in my car, and it works perfectly, it has power, the sound quality is good.
But every time I stop the engine the radio stops as well and when start the engine again the radio doesn’t start by itself I have to push the turn on button, and every time with all the settings resetted.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi,
What is the make and model number of the radio?
What is the year, make and model of the vehicle?
完成的
I have a Lexus NX 300 and when I turn my car on it goes directly to disc? Before it was on the radio.
完成的
添加一条评论
1个答案
You need to connect up the ignition wire, depending on your stereo there are 3 wires, 1 red for constant power, 2 yellow for ignition and 3 black for ground.
if everything looks correct then swap the red and yellow wire around. I know with pioneer stereos in some cars those specific wires need swapping.
Then the stereo will will come on automatically when ignition is turned on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sergiu Butnaru 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 74
总计 2,811
