跳转到主内容
Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
209 个问题 查看全部
Can I repair broken IR and Fan connectors - sheered off at logic board
I have a Mac mini mid-2011. I installed an SSD as the second drive.
It works but I have broken the IR and Fan connectors - sheered them off at the logic board.
Is it possible to repair these two connectors with “micro-soldering”?
What tools do I need to do that please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
@cooker47 that will depend on how they are broken and if they destroyed the solder pads. If so, you will most likely have to run some jumper. There are no schematics or boardview for the Mac Mini so that would mean it could get tough. If the pad are still decent, you can resolder the connectors (or buy new ones if the originals are destroyed). Take a look at the answer I popped off the fan connection from the logic board...Fix? and see how to solder it. Different connector, same idea. Post some images of our damage so we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 3
添加一条评论
I would directly solder wires to motherboard
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Cook 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 108
