跳转到主内容
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
58 个问题 查看全部
Dual fuel tank issues
Switched from front tank to rear and the truck shut off immediately. Switched back to the front tank and the truck still won’t get fuel or start. Any ideas why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be the switch is bad and the fuel pump for the rear is bad. It proabably both, when you flip the switch to the rear is shuts off due to a bad fuel pump and aint going to be able to pump fuel and when you flip the switch back it aint sending a current through to switch back to the front tank but it also could be a wiring problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
binghamshaun73 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,151
