跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No service (GSM signal: 3G/4G and SMS but wifi works fine)
Hi !
I hope you’re all doing good :)
I recently changed the screen and the battery of my Iphone 6. Everything was working just fine for a week until yesterday. I can neither receiver / send SMS, nor access 3G/4G.
J'ai démonté et remonté l'écran et la batterie
  • I disassembled and reassembled the screen, the battery and the coax connexion
  • I restored the phone and the carrier parameters
  • The IMEI is still running
  • The SIM card works on other phones
  • I downloaded the last IOS and Itunes version
What should I do ?
Could it be a motherboard issue or a welding issue ?
Would it be worth trying to replace the lightening dock ?
Thanks in advance for your help !
Margaux
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Is the IMEI showing also when dialing *#06# or just in the phone info ? If it does it shouldn’t be the baseband IC issue many iPhone 6 show when the logic board was flexed or badly hit. If you get IMEI when dialing it might be worth trying replacing the dock to not let anything untried, but it might nonetheless be a logic board issue
这个答案有帮助吗?
得分 1
添加一条评论
Try replacing the charging port flex otherwise cellular data is turn off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
margox 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 60
