跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
6s+ Touch ID doesn't work
Last summer, my phone got wet. I took it apart and dried it out but the screen was shot. Ordered a screen from iFixit, moved my home button over and everything has been working great. Fast forward 3 months and I cracked the screen. Ordered another screen from iFixit (and a new battery) and just now replaced them, following the same instructions as before. Yes I moved my home button over. Everything seems to work but no touch id. Home button goes to home screen but I can’t add a fingerprint or otherwise get a response from the touch id sensor. Open the phone and reseated all connectors (home button, display, digitizer, camera) but still no luck. Any ideas. I read it could be a defective screen??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Just to close this out, iFixit sent a replacement screen and the new one works fine with TouchID. The 1st screen also had some auto-brightness issues and I think that is back to normal also with this replacement.
完成的
添加一条评论
2个答案
已选择的解决方案
You either damaged the Home Button or the Link flex that runs under the backlight on the screen is defective/damaged. Try installing the original screen with the Home Button. If it works with the original screen, it means the replacement screen is defective. If it doesn’t work, then you probably damaged the Home Button. Inspect it with magnification. Even the slightest tear can render the TouchID non-functional.
这个答案有帮助吗?
得分 3
3条评论:
Ok, I moved the home button back over to the old cracked screen and Touch ID works fine. So I'm guessing this latest screen from iFixit is defective? I checked the cable on the new screen under a magnifying glass and it looks fine. How do I get a replacement?
完成的
I should also add I did a DFU and reinstalled / recovered the phone. That did not fix Touch ID. Works fine on the old screen. I sent an email to support@ifixit.com. Will see what they say.
完成的
Please contact iFixit support. We are just volunteers helping people fix their stuff.
完成的
添加一条评论
With water damage, there can always be problems down the road. The first thing you should test is whether it is a problem with the screen. If you still have the broken screen, test and see if the home button works on that. If it doesn’t work on that, then the chances are that the home button is broken. Also inspect the flex cable for any tears.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bruce White 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 187
