跳转到主内容
An Android 4.4.2 smartphone released November 1, 2014.
51 个问题 查看全部
Why cant I touch the screen on the phone
I think my mother board is gone out how do i fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@khunt2002 Is the touch screen unresponsive?
完成的
添加一条评论
1个答案
if your touch screen is unresponsive, there are a few things that could be going wrong.
1) most commonly, your digitizer is failing. The digitizer is the touch processing panel under your glass. you can try to get a new one and see if this fixes your issue.
2) this is less common, but will cost less to fix, which would be a software bug. run a factory reset through your recovery mode on you device to see if it fixes your touch.,
3) board level failure. the least common to cause a straight lack of touch, but the board may be having issues. without excessive training in Microsoldering, as well as access to the schematics for your device, you will be unable to repair this, and will have to replace the motherboard with one from another device instead.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyra Hunt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 106
