跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
247 个问题 查看全部
Right fan running at 6000RPM after liquid damage
Hello everyone,
I hope you’re all having a great day/evening!
So I’ve had the misfortune to spill some orange juice on my brand-new 2016 Macbook Pro. Well, actually, not on it because the juice went sideways but somehow got into the laptop through the left USB-C ports. Funny, when you think how much you pay for such a machine!
Anyway, the laptop seemed ok at the time. I was able to run multiple Adobe CC apps with no issue whatsoever. Only, the Touchbar was completely black at times. To be honest, I only noticed that later that day because, well, let’s just say the Touchbar was just kind of a useless thing for me and I wouldn’t use it…
I took my ridiculously expensive Macbook to an Apple Store to have it cleaned but they refused. So I took the matter in my own hands and opened it myself to give it a nice clean with some isopropylic alcohol. It didn’t work. Even worse, the fans were louder and the battery was not working. It was going from 40% to 0% in seconds. Sometimes, it wouldn’t power on at all.
Just so you know, all this happened in March. After my failed attempt to clean it, I just shoved it in a drawer and that was it. I was done with Apple and their high-priced but super-flimsy products. I mean, if this happens when you spill liquid near an Apple machine…
I went to another Apple Store (Genius Bar) in May. They run the famous Apple Service Diagnostics, found loads of issues with the battery, fans, etc. Needless to say, the kindly suggested I pay at least 1,100 to have it fixed. Either that, or I pay the full price for a new machine. No way, man. Just. No. I was totally appalled at the kind of service they were providing, and it was so expensive to fix that it just wasn’t worth it.
So I waited another 4 months before taking it to a third Apple Store (Genius Bar), where they tried to get me to buy a new machine as well. Only, they didn’t run diagnostics because they couldn’t get it to power on, so they supposedly taken it somewhere in the back to open it and have a look inside. It took them, like, 5 minutes to come back and tell me just how badly it was damaged. The battery, the logic board, everything was screwed. Again, they suggested I pay a minimum of 1,100 to have it fixed or buy a new machine. Needless to say, they said the total price for the repair could get to, like, nearly 2,000. Umm… Ok… But no, thanks.
By this time, I was so sick of Apple that I decided to take the matter in my own hands again. So I opened the Macbook, took the logicboard out and submerged in rubbing alcohol (70% isopropylic alcohol, 30% distilled water + blue colouring) for 48 hours. I assembled it back, but it refused to power on. Then I got an ultrasonic bath and gave the logicboard a nice, hot bath, followed by a nice 1-hour stay in the hot oven. It must have enjoyed it, ‘cause it worked! It was powering on, but the right fan was very loud and rotating at 6000RPM. Another issue? I was getting an error with the SSD. It couldn’t be read and the Macbook wasn’t booting into OS.
Of course, I took it out again, gave it another 2 ultrasonic baths + oven stays using a DIFFERENT cleaning fluid for the ultrasonic bath (which I think was of much better quality than the first and specially made for PCB). Hard drive problem solved. The Macbook was booting, the battery was perfect, the Touchbar was working. The machine was actually working PERFECTLY. Unexpectedly so. But the right fan was loud… very loud. I also noticed it started rotating way before the left one when powering on the machine. iStat showed 6000RPM for the right fan and just about 2000RPM for the left one.
At this point, I tried resetting the VRAM, SMC, and basically did everything that was humanly possible, but nothing. Apple Diagnostics only says there’s an error with one of the fans (PPF003). And this has been giving me a splitting headache ever since!
Oh, by the way, it seems that removing the logicboard so many times wasn’t very good for the wireless antenna cables. In doing so, I also had to remove the black coaxial antennas, which cause the wee soldered attachments to come away from the logicboard. Go figure.
Just to recap:
  1. I spilled orange juice near the Macbook Pro. I powered it on and there were some issues with the Touchbar. I opened it, cleaned it with some Q tips dipped in isopropylic alcohol, but surprise! There were new issues with the battery, the fans were loud, it wasn’t powering on properly.
  2. The Macbook stayed like this for months (no usage).
  3. After several ultrasonic baths, everything is well (including the battery and Touchbar), but the right fan is just as loud, which makes the Macbook kind of nonfunctional. Plus, the black coaxial antennas are damaged (I tried taping them and the wireless is working, but no idea how well it’s working).
So right now, I have a fully functional Macbook with a very loud right fan that spins at 6000RPM. Temperatures are fine, no high CPU usage.
I already tried:
  1. replacing both fans with other fans that I knew for sure were working
  2. resetting the SMC and VRAM
  3. all kinds of tests by removing flex cables, connectors, etc.
  4. disabling Wi-Fi from OS (thinking the problem with the right fan may be due to the damage to the wireless antennas)
  5. I looked for apps or processes running in the background that might be causing the right fan to behave like that (such as pending printing jobs)
…nothing worked. Any recommendations? I’m totally heartbroken here.
But please, don’t advise me to go to Apple Genius Bar. A child is a lot more genius than they are! And don’t tell me to go to a so-called ‘specialist’ because, while I don’t mind paying for this, the only things that all ‘specialists’ in the UK know is replacing the screen and installing OS. Also, advising me to find any sensor isn’t a good idea because I’m not good at this sort of thing. If I were, I wouldn’t be posting here…
By the way, if anyone wants to know anything about the interior/construction of this Macbook or wants to see photos of it opened, just give me a shout! :)
Temperatures with the right fan at 6000RPM
Broken coaxial:
And a video with the behaviour here: https://youtu.be/FI8SWiLBHUc (you can see that the right fan begins spinning the moment I power the machine on, and it spins a lot faster than the left one).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Same problem here but with left fan
完成的
添加一条评论
3个答案
已选择的解决方案
Get yourself a fan controlling App, there is more than one out there, personally I like Macsfancontrol https://www.crystalidea.com/macs-fan-con..., if everything else works fine that should be enough.
In case that doesn’t work it means you have a more serious problem at logic board component level but Apple won’t be able to fix as they don’t offer such repairs, you won’t be able to fix it and since you don’t trust “specialists” the only alternative solution left is to replace your logic board yourself.
这个答案有帮助吗?
得分 3
1条评论:
Triple that! MacsFanControl is it go-up and I use it in Windows 10 because it is imperative to keep the MacBook Pro COOL and those with DUAL GPUs are beyond toasty on a good day. On a bad day....you'll flat roast your critical circuits to a crisp & that's a costly mistake that makes sloshing OJ across (and thereby into) your laptop, well, positively brilliant!
完成的
添加一条评论
As a temporary band-aid until you get this fixed you could use Macs Fan Control to tone down your fan.
这个答案有帮助吗?
得分 1
添加一条评论
Hello, have the same issue( Have you fixed this problem?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
IHateApple 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 32
总计 3,299
