跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
one of the screw hold breaks and I can't turn on the phone
My iphone 6 has a long time problem with the display, some time it turns on when I pressed the power/home button but some time it doesn’t, while the sound and touch id all still works normally, so I suspected that it’s just a loosen cable problem.
So I opened the phone and unplug and replug the cables, but then I broke one of the screw holes when I try to put back everything, and now I can’t turn on my phone. Some searching shows that the screw hole that I broke was responsible for the power supply. How do I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If you had a good microscope and excellent microsoldering skills you could rebuild traces that got damaged..it’s not a DIY job, either you’re a pro or you’ll have to find someone do it for you.
这个答案有帮助吗?
得分 1
2条评论:
I don't have the tools and skills. How much does it cost to fix this in stores?
完成的
@hoyun Cost of repair may vary with the place you are living..easiest thing is to find someone reputable in your area, but some repair shops offer mail in service too. Good news is many shops offer a no fix no fee service..your issue is quite straightforward repair, thus it won't be too difficult to get a quote.
完成的
添加一条评论
This is known as long screw damage. The traces underneath the logic board have been torn off by the screw, and now the phone is missing vital traces. This can be fixed by a microsolderer, but is a more of an expensive fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hoyun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52
