screen is cracked and moisture appeared in the crack
My phone screen is cracked and moisture appeared in the crack can I pour isopropyl alcohol on the crack to dry out the water
@carroll1218 , i would leave leave the alcohol out at this stage. Unless you want a few more problems. You may need to replace the screen, but if you have moisture in the phone you need to open it and dry it out. Up to you but you can leave the phone as is if it is working, or try and make sure there are no other dramas.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 216
