Vertical Lines on Samsung LED TV
I have a Samsung TV (Model No: UA46D5500RR) which has now started showing vertical lines on the screen. The screen is just filled with those lines.
TV: Samsung 46''
I am also attaching the image below.
Update (11/06/2018)
My bad. Here is the image of the lines on my television.
3条评论
you haven't attached a photo. are the lines moving or always in the same place? are they present on start up?
由 pollytintop 完成的
@pollytintop : The criss - cross lines are always there on the tele. they are visible from the boot till I close my tele.
由 Safal Verma 完成的
I'm getting this issue as well too only mine are moving across the screen. They show up in my xbox dashboard settings they are very easy to see on the black and grey background. They are showing up a lot in the tower in destiny 2 and in the division 2 in some areas. They are thick dark vertical lines that travel across the tv. They are very transparent/faded.
由 Irish Cowboy 完成的
