跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
My ipad pro doesnt charge
the device doesnt charge when plugged in. The charger is confirmed to work, and i have already replaced the battery. Im thinking that the large ribbon cable that lays flat at the bottom of the device is damaged. But i am not sure, any ideas would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your Tristar IC is likely damaged or broken. That requires either a logic board replacement or a microsoldering job done. I would talk with your local microsolderer about this, replacing the Tristar IC is a lot less then replacing the entire logic board.
这个答案有帮助吗?
得分 1
3条评论:
I cant seem to find a tristar ic for this ipad model would you be able to help track one down? Also the model id is a1652.
完成的
Also can i change the logic board and just use password to unlock the device without using touch id
完成的
I couldn’t find a Tristar for your model iPad either. Indeed you can do that. It’s not the least expensive option though.
完成的
添加一条评论
添加你的答案
Michael Johanson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 111
