跳转到主内容
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
317 个问题 查看全部
Ideas of how to remove or cover up these scuffs?
Guess what? I am thinking of buying yet another older Mac.
However, I try not to pay very much for these older Macs so I end up getting either broken systems to fix or Macs that are “bottom of the barrel” cosmetically.
I found a 2006 Mac Pro on eBay for 150$ that is fully working but cosmetically damaged.
Before buying this Mac I have a question…
How can I remove or cover up these scuffs so this Mac can actually look decent?
Update (11/05/2018)
Thank you both! I’ll try the sandpaper and epoxy first and then I’ll move onto spray paint if the epoxy and sandpaper is a no-go.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I have had good luck with this paint, but test on bottom to see if it works on yours:
Krylon KSCS032 Short Cuts Aerosol Spray Paint, 3-Ounce, Chrome
https://www.ebay.com/itm/Krylon-KSCS032-...
这个答案有帮助吗?
得分 3
添加一条评论
I’ve used Black contact paper. I would use some sandpaper to remove any high points and some epoxy filler for the deep gouges. Use some cleaner to get the dirt and oil off beforehand.
这个答案有帮助吗?
得分 1
添加一条评论
If you don't mind severely altering the look of your macpro. There are vinyl film products that other PC modders use to alter the appearance of their case plastics/hardware. Should hide such things nicely (but not fix it for resale).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
