My dsi xl will not charge or turn on
My dsi xl wont register that its plugged so it wont charge so i cant turn it on what do i do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi!
Can you confirm that the power adapter is working? Can you check it with a multimeter?
完成的
I do not have a multimeter is there a way to check it without one
完成的
do you have another device that uses the same pin as the ds? If you do, try charging it with that and seeing if the charger works on another device.
完成的
添加一条评论
