跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Touch screen not working after replacement
I replaced the touch screen on IPhone 3G according to video and connected ribbon cables accordingly. Phone turns on but slide to unlock still does not work even after opening it up again and reconnecting all cables. I have also done a hard reset but still no luck with touch screen picking up my touch. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
reopen the phone inspect cable end of digitiser and the motherboard for dirt/damage...give it a quick dust to get rid of anything you can't see, and reconnect the cable 2...it makes a secure pop or click type noise when it's on properly. other than that make sure you have the right part and try hard reset after you've reconnected.
这个答案有帮助吗?
得分 5
3条评论:
+ Makes my heart warm when you talk like that. All the right words using all the senses to fix something. Most people only include visuals and leave out words describing sounds etc... when it is put together right.
完成的
I like the keep it simple stupid (kiss) way of thinking..i was a beginner once and dazzled by all the posts out there using big terms and abbreviations, have no idea what they were on about...not much help when you're starting out. Never forget where you come from!x
完成的
+ that's why you're such a valued contributor around here
完成的
添加一条评论
Something that also helps with some connection issues is transplanting the small piece of foam rubber sticker from the top of the connector of the old digitizer and putting it on the new one, it usually has an orange sticker with a number on it.
If there's nothing wrong with the connection then it usually works without the foam piece, but the piece will sometimes give it that extra pressure when closed to help.
Also, when removing that foam sticker make sure you peel from underneath the sticker not in the middle of the foam. Get in between the sticker and metal of the top of the connector.
这个答案有帮助吗?
得分 2
1条评论:
+good advice chris
完成的
添加一条评论
Chris Cooper is absolutely right. Most new digitiser replacements come without any soft foam padding on the connectors. These are sometimes essential for keeping the #3 connector down and steady. Keep your broken parts for these and other things like visual comparison. Ever had a good look at a 3G connector and a 3GS?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joanne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,447
