Machine is pulsating
There's a troubleshooting guide for a "pulsating" machine: https://www.dyson.co.uk/support/journey/...
"The machine is designed to pulsate. This is an audible feature that indicates a restriction of airflow and prevents damage to the motor. This is usually caused by a blockage within the machine or a clogged filter.
When the machine is pulsating, it will switch on and off in quick succession. Make sure the machine is cool before running through the following checks."
Here are the recommend steps to sort out the problem:
1. Open the bin
Press the bin base release button to empty bin and leave the bin base open.
(if that doesn't solve the problem proceed to step 2)
2. Check for any obstruction of :
- cleaner head
- wand
- bin inlet & flap
(if that doesn't solve the problem proceed to step 3 - but you better do the next steps outside in the garden ... )
3. Remove the bin
“Using the Combination tool, brush away any dust around the shroud of the cyclone.
Once cleared of any dust, press and hold the trigger for 10 seconds.”
(if that doesn't solve the problem proceed to step 4 - this really better outside in the garden ...!!! )
4. Remove the pre-filter
“Pull the pre-filter out of the top of the cyclone and place the palm of your hand over the hole where the filter is usually positioned.
Press and hold the trigger for 10 seconds” (better with Max.Power!)
Take care: there might be clouds of fine ‘moon-dust’ blown out of the machine ...
If that doesn't help, Dyson recommends to contact support …
Check ***Dyson v6 Absolute Main Body Replacement***
There are two little metal tabs sitting above the lever of the bin and are meant to make electrical contact to the wires running around the bin and down the wand to the motorhead to power the rotating brush.
Those metal-tabs tend to get bend and/or their ends might have become dislocated out of their brackets.
Best to follow the steps of removing the Main Body from the Cyclone to get them metal-tabs back in place.
5条评论
Hi
I’m aware that you cleaner the bin
But from my experience this issue is caused by the little dust flap where the wand connects getting clogged with more dust and debris
Hopefully this helps as from what iv seen it tends to be this before anything else
But if it don’t give me a shout and il try again!
由 HelloMacOS 完成的
Mine has started to do the same thing. I noticed there were no answers. I wish I knew what to do.
由 JUDIE E. SIMS 完成的
Look at the head and where the dirt goes from the head up into the tube. Mine got blocked there and did the same thing. Really hard to notice if you're not looking for it. Clean that and mine runs perfectly. I now know to check it and clean it regularly.
Hope this helps.
由 jackie_mctaggart 完成的
This suggestion just fixed my vacuum. Thanks for the tip. Same thing happened with my furnace, unfortunately, that one cost me a service call.
由 Michael Balogh 完成的
This just fixed mine as well...thank you jackie_mctaggart
由 Jill Baderdeen 完成的
