跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
Magsafe 2 Connector Burnt
I got my MacBook repaired with this exact same issue in February of this year, the charging port has noticeable burn marks around the 2nd and 4th pins. Now once again it is having the exact same issues, has anyone else had a similar issue to this? What did you do to fix it? I have an apple generic charger, and the board for the magsafe was already replaced once.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your answer is “generic” charger, the quality of which is probably far from what an original charger is. Just trash it and look for an original one, even a 2nd hand would do, but do not endanger an expensive logic board for a little saving on the charger. If it’s just the charging port that’s gone bad consider yourself lucky, at times everything gets burnt along the power/charging circuit. On top of that, uncertified chargers may be dangerous for you and your households as they may start fires.
这个答案有帮助吗?
得分 3
5条评论:
I worded that badly, it is an apple original charger, bought a new one when I got the MagSafe replaced in February.
完成的
@bedoretj Well, never had a single problem with any of the hundreds of Apple chargers I had tried in many years. May I ask where did you buy it from ?
完成的
the apple store in short hills, NJ
完成的
That sounds like a reliable enough source to buy an Apple charger. Can't find any reasonable explanation to your issue then, besides severe voltage/current spikes on mains, is that a possibility ?
完成的
If you are talking in terms of power surges, I have it grounded on the power strip that has surge protection.
完成的
添加一条评论
This is not really a good answer, since the same happens with expensive original chargers. Right now, it has heppened about the 6th time with the original, 140 dollars in Costa Rica one
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TJ Bedore 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 1,235
