Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 个问题 查看全部
recovery mode after a succesful restore...
There is NO error, it restores normally but when its over, it says it worked fine
the phone reboots and its in recovery mode. i repeat all this and still wont reboot.
I got the phone today and it was working fine.
i opened it and it has water damage i said ok the phone seems to work so no problem. i refurbished it completetly and when i turned it on it didnt work :(
Any ideas?
home button didnt work prior to restoring...
im assuming i either damaged it or its just the water damage acting up
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
did you replace the battery as part of your refurb? which parts have you changed?
i replaced the housing and the screen
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
4个回答
已选择的解决方案
Jonas, I would go ahead and follow this guide Electronics Water Damage just to make sure that you wont have any issues with the phone down the line. To get it out of recovery mode I use Recboot.. Good Luck
这个答案有帮助吗?
按维修分数 2
评论:
I have an iphone 3gs 16gb that was unlocked and recboot is not working to get it out of recovery mode
ive used redboot to kick another 3gs out of recovery but i seem to have no sucess with this one.
when i restore it it gives me error: 28 on itunes
do you have any suggestions?
Unknown error 28
Problem restoring your device (Problem Irreversible)
Solution: None.
Contact Customer Service for Apple iPhone replacement (if it is still under warranty)
These errors may indicate a hardware problem of your device. Follow the procedures described in this article and also try to perform a restore by connecting to a computer and a network that you know, to isolate the problem to the device.
If the IMEI number or the MAC address is not specified or corresponds to a default value, it can also confirm that the problem is of a material.
some people have had success by changing the dock connector...
添加一条评论
Thank you so much, recboot wasnt working until i clicked on Exit and thats the only one that opened up and it just kept rebooting the phone on and off im like uhhhhh so i disconnected and it started doing something i never saw before and boom it was restored lol.
thank you! your the best btw:)
i will try this on other broken phones stuck in recovery now :)
这个答案有帮助吗?
按维修分数 0
添加一条评论
Have you tried it on other phones, does it always work or are some just not goin to fix?
这个答案有帮助吗?
按维修分数 0
添加一条评论
The easiest way to exit iPhone Recovery mode - ReiBoot. No need of home/lock button, no need to connect to iTunes. Only one click to exit iPhone Recovery mode.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Jonas 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 5,093
