跳转到主内容
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
Lens error, restart the camera
I am getting this message when I press the on button. The lens is not retracting in.
Lens error, Restart the camera.
Can you please help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Pinky Kasotia , this is usually caused by sand or grit interfering with the lens extension mechanism, or the camera's been dropped with the lens extended. It is also possible that the camera has been powered on, but the lens had been blocked preventing its extension....okay there are plenty of causes. Check on here for a more concise solution. Good luck
这个答案有帮助吗?
得分 2
添加一条评论
lens do not get back when on/off button is pressed.
这个答案有帮助吗?
得分 2
1条评论:
same answer as above :-)
完成的
添加一条评论
make sure you are not holding the lens when you turn the camera on.
这个答案有帮助吗?
得分 1
添加一条评论
can you help for restart the camera
这个答案有帮助吗?
得分 1
1条评论:
Camera lens does not move when switch.
完成的
添加一条评论
添加你的答案
Pinky Kasotia 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 31
总计 6,137
