跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
What to do if I dropped my 2DS in water a few weeks ago?
So, My 2DS was in a water spillage in my bag and I did not notice until a few weeks later. Whenever I try to charge it, the orange light lights up for about 2 minutes, and when I try to turn the 2DS on, the blue light doesn’t light up at all. I already tried opening up the back and cleaning the motherboard and the components inside with achohol and a cotton swab. I also tried reattaching the two ribbon cables that are both facing up. And I am broke, so I can’t go to a repair shop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
First Name Last Name  in your case you may need more than a cotton swab. I suggest that you totally disassemble your device using this guide Nintendo 2DS Motherboard Replacement
Then follow this guide 修复iPhone 的进水故障 about how to clean the board. The guide was written for an iPhone but the principle about the cleaning still applies to your DS as well. Once you got it properly cleaned, replace the battery and re-evaluate.
In the meantime you do not want to try to charge or to turn it on. This potentially can make bad things worse.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
Nintendo 2DS Motherboard图片
指南
难度:
中等
30 - 40 minutes
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
First Name Last Name 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 409
