跳转到主内容
The Nerf N-Strike Elite Mega Magnus is Nerf blaster released by Hasbro in 2014.
3 个问题 查看全部
How do I repair the chamber flap on the Nerf Mega Magnus?
I recently bought a used Magnus and I took notice why people didn’t want it. The chamber flap, which probably isn’t it’s name, is too loose or weak to hold a mega dart being chambered into the barrel. It just gets pushed out of the way, making me have to push the dart back in to have it fire effectively. Is there any way to just fix it outside the gun or do i have to screw inside and replace a spring?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
If you take the rifle apart, there is a place for a bunch of the safegaurds so you dont chop of your finger, the red safegaurd is what is blocking it, tap it, and the trigger should pull back
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem too. You want to take the gun apart,remove the barrel and then take out the front orange piece.it separates into two parts and on the Inside is a screw and Spring,this controls the little plastic piece that slides up to stop the flap. you may need to tighten or loosen the screw,or just move the piece up and down a bit to loosen it up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cowerosity 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 463
