跳转到主内容
ASUS Chromebook Flip C100P was released in 2012. This was the first-ever 10-inch convertible Chromebook released. It is a laptop running Google's Chrome OS. The C100P came available with 2GB or 4GB of RAM, and silver as the only color option. Repair of this device requires screwdrivers and prying tools.
20 个问题 查看全部
ASUS Chromebook C100p What should I do if I dislocated my left hinge?
I’ve only had my ASUS C100p for eight months and I have already damaged it. Everytime I open or close the chromebook, the hinge makes a cracking sound. Since I can flip the chromebook, when I bend it over like a tablet, the hinge becomes exposed and the monitor screen partially comes off. For some reason I haven’t noticed until it made the sounds. I’m just wondering if I should try self-repairs or going to a repairman.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I would give it to a reputable repair shop to get it fixed.
It sounds like the actual hinge itself has cracked. It could be the screw standoffs on the housing of the chromebook on the bottom that has snapped.
Sometimes they require replacing the hinge and/or use of epoxy to glue the broken screw standoffs for the hinges in place. If it isn’t done properly (too much / too little epoxy) you won’t be able to close the casing of the laptop properly so like said before, leave it to a repairman to do.
这个答案有帮助吗?
得分 2
添加一条评论
You’ve probably long-since dealt with this, but I recently had the same problem—I suspect many right-handed people will have this problem, since I suspect the problem is largely from adjusting your screen angle with your left; vice versa for the left-handed folks adjusting their screen with their right hand—and might as well share how I resolved it: I ordered new hinges off eBay—it was a little hard to find them (don’t buy anything that looks like your hinge cover/case with silver wings sticking out of the side; close, but that isn’t the right part), and when I did the cheapest set was $17—and, when they arrived, found a couple guides online about how to disassemble the ASUS C100P (you will need to open the screen case, the hinge case, and the body of the computer; you don’t need to fully remove the front of the computer if removing the cables to your keyboard and touchpad freaks you out a bit—just be careful!—since you only need access to the inside of your computer near the top) and replaced them myself.
The hinge design for the C100P is impractical as !&&*—the shape for the right hinge and the left are distinct, so you can’t just flip a RIGHT hinge and use it for your LEFT, if, for some reason, you have an extra right like I now do--there are two silver wings, the one which goes into your screen case—three screws and two holes that snap into the black plastic of your screen cover; make sure those are in place, I had to superglue repair one of those plastic-bits—is a bit more wing-shaped and the lower one—looks kind of like someone bent a puzzle-piece out of shape, almost; there’s four holes there and another divot that looks like it makes room for something else—both of which are connected to a dark bit of metal, that then looks a bit like a cable, and is held together by another silver piece with room for some screws (three).
The text engraved in my right-hand eBay hinge reads: SNR C100PA-R, which may be a part number. There’s no such thing on my old let-hand hinge, and I’m not entirely inclined to pop open my screen again just to have a look for part numbers.
Be careful during reassembly, I’m now dealing with an unresponsive touchscreen which may or may not be related (and which makes this thing pretty inconvenient and frustrating to use, but I digress).
Good luck!
这个答案有帮助吗?
得分 2
1条评论:
my right-hand hinge broke into 3 pieces... I'm debating if I buy a replacement hinge or just sell my chromebook for part..
完成的
添加一条评论
添加你的答案
Greenpoeguy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,757
