跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
355 个问题 查看全部
The true amount of maximum RAM?
I understand that in the 2012 unibody models that you can upgrade the RAM to 16 GB, even though Apple says that the max RAM is 8 GB. Is this the case with the 2011 unibody MBPs?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
You know better than to not be specific as to exactly which machine.
@mayer How was I not specific? The machine I am referring to is the device I listed.
this year's MBPs? 2018? Is English your second language?
Fine, that may have been a bit vague. However, I got the answer I needed.
I really didn't understand the question. You can get offended or you can work on your composition. This is not the first time you have lacked clarity. If you intend to go to college, you will need to work on this. The Cardioversion didn't work. next procedure is called an ablation. I'll be scarce for another week.
显示更多的1条评论
添加一条评论
iPhone 电池维修工具包
只要 $29.99
Buy Now
iPhone 电池维修工具包
只要 $29.99
Buy Now
1个答案
已选择的解决方案
16 Gig actual 8 as per Apple see Mactracker
这个答案有帮助吗?
按维修分数 3
评论:
Yes, this is correct. My friend has this Mac and he was able to use two sticks of 8 GB RAM in his MacBook Pro. Worked just fine.
添加一条评论
添加你的答案
Aaron Cooke 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 68
