跳转到主内容
Repair guides and troubleshooting for the HP ProBook 4440s. Featuring a 14" screen and Windows 7 operating system, the ProBook 4440s can be identified by model number C6Z33UT.
15 个问题 查看全部
Is there any 1080p screen alternative for this model?
a time ago i saw in a HP forum that a user replaced a HP Probook 4440s screen with a 1080p one, does someone here know the exact part model and if it´s something extra necessary for the procedure?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
This is the only replacement screen that I found that is supposably “HD” is one on Amazon with the resolution of 1366x768. Sounds like your best option at the moment.
https://www.amazon.com/HP-PROBOOK-Replac...
这个答案有帮助吗?
得分 1
评论:
Well it's not 1080 but it will work perfectly to replace my dead pixels problem Thanks!
完成的
@spannerws No problem. However, after further research it doesn't look like there is a 1080p screen available for this model. Bummer!
完成的
添加一条评论
添加你的答案
samuel 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 41
