跳转到主内容
MacBook Pro won't turn on after logic board replace. Dim green light.
I just replaced the logic board in my late 2011 a1278 Macbook Pro Unibody. It was diagnosed dead by apple so I thought I could replace it myself. So I put it in and it would not turn on. Just shows a dim green light on the charger. I bought the logic board for 250$ off Ebay from a good seller. The board doesn’t get warm at all even after charging for 4 hours so I don’t think it is getting power. Please help me!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
A dim MagSafe LED often points to a bad charging logic on the main logic board. So I’m suspecting the replacement board you got is likewise damaged as well.
You still should check the DC-In board for damage. Here’s the IFIXIT guide to get to it: MacBook Pro 13" Unibody Late 2011 MagSafe DC-In Board Replacement and heres the replacement part if you need it MacBook Pro Unibody 13" and 15" MagSafe DC-In Board. Make sure the small SMT components are not missing or damaged on the logic board.
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board图片
产品
$9.99
这个答案有帮助吗?
得分 1
2条评论:
I had replaced it already no luck
完成的
Sorry, I guess you'll need to try to get the board exchanged out still again.
完成的
添加一条评论
添加你的答案
Jimmy Robertson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 199
