跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
Screen only works well with external display.
Screen goes dim without a connection to an external monitor. Works fine with an external monitor. By itself it sometimes works but will flicker every once in a while. Or it will just remain very dim. F2 key is unresponsive during these fits. Screen returns once external display is plugged in.
I have a new logic board and new battery installed. The display problem existed before this repair.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Try to check the connection to the display may be they are rusty connectivity between the connection.
完成的
添加一条评论
1个答案
已选择的解决方案
Flickering is quite often related to LVDS cable issues. If logic board was replaced I guess it was for a reason..if that involved liquid damage or image issues it’s likely cable was damaged and needs replacement too.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Mark Waddington 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
