跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Power LED #1 flashes after replacing faulty PSU
My friend sent me an iMac that won’t boot up, no fan, no hard drive movement. I examined the power LED, even the power is plugged in, none of the LED is on. Then I replace the PSU. I thought the problem is the PSU. Here’s the funny thing: after I replace it, the power LED#1 flashes once when I plug in, then nothing happened afterwards. No LEDs, no fan, no movement. What could go wrong?
Here’s the VIDEO
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly you have a logic board failure. It could be more localized to the GPU board if the board is shorted out. For most people replacing the full logic board is just the easier path.
Here’s the IFIXIT guide: iMac Intel 21.5" EMC 2389 Logic Board Replacement and here’s the needed part: iMac Intel 21.5" EMC 2389 Logic Board
While I love these older systems as they are more repairable than what Apple is selling now you are going to hit the issue of Apple moving on with their OS. Mojave is not supported on this system as the GPU logic does not support Metal services needed in Mojave.
While Sierra and High Sierra as still supported keep in mind in a few years they will be end of life’d and no longer have security updates.
Replace a logic board compatible with the Model A1311 Mid 2010 21.5" iMac. Fix processing issues like unexpected shutdowns, reboots or water damage.图片
产品
$89.99
这个答案有帮助吗?
得分 0
1条评论:
Thanks man, this just confirmed my nightmare ): But I'll fix it anyway. This beauty is a classic!
完成的
添加一条评论
添加你的答案
norton801118 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 99
