跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
531 个问题 查看全部
The Installer payload failed signature check.
I’m trying to install Sierra on my mac and i’m having trouble with getting past the error “The Installer payload failed signature check.” I’ve reset the time, installed new ram, and wiped the drive. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个回答
已选择的解决方案
Try downloading another copy of Sierra and creating a bootable USB with that installer. Your current copy is either fraudulent or corrupted.
这个答案有帮助吗?
得分 1
评论:
I work at a Phone/Computer repair store and we have "known good" usb drives. were going to try and install El Capitan And see where that leads us.
完成的
@danj Yes, we have inputted the correct date and time settings.
完成的
@acervasio Just making sure you are doing the bootable USB process correctly; You are downloading the ElCap/Sierra installer from the Mac App Store and you are then creating a bootable USB using "createinstallmedia"in Terminal. Correct?
完成的
Where did you get the installer? I strongly recommend you only get it from the Apps Store. Other sites that offer the file could have altered it.
完成的
显示更多的10条评论
添加一条评论
添加你的答案
Austin 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 16
过去的30天: 49
总计 4,376
