跳转到主内容
修复你的物品
维修的权力
商店
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1172 个问题 查看全部
Stuck on "Get Started" screen (home button damaged)
Hi guys, so I had a customer walked into my shop today with an iPhone 7 plus stuck on the “Hola/Get Started” screen, she cant get through it cause her home button is damaged. Any idea how I can get through it? I dont have access to settings to enable assistive touch because im still on the get started screen.
I know only Apple can fix the home button, but im not looking to get the button fix. Just pass through the get started screen and use the iphone as usual with assistive touch.
cheers
Mike
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个回答
已选择的解决方案
Is there an option for “Accessibility” on the screen? If so, activate VoiceOver and you will be able to click the screen. The other option that may work is to connect the phone to iTunes, set up as new device and then select VoiceOver from the Accessibility section of the iTunes screen.
Once your in the phone, you can turn on AssitiveTouch.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
You really can’t get past the “get started” screen without having a functional home button in my experience. Guess it’s another trick up Apple’s sleeve to try and brick your phone and then make you spend money on fixing your phone.
这个答案有帮助吗?
得分 2
评论:
Not even a hidden "press some button a few times" to get siri or anything to help get past it? If so then that is scary. There is no genuine apple store in my country.
完成的
添加一条评论
We sell these dongles for this exact purpose at iPad Rehab Supply. https://ipadrehab.ecwid.com/#!/iPhone-Ho...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Yates 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 228
